wtb nissan rear axle shims
Does anybody have any shims from a c200 rear diff? im talking about the ones that go between the diff housing and the axle flange , i assembled my diff only to find it had way too much preload on the axle bearings so i need to add some shims and dont want to wait two weeks for nissan to get some from japan.
Re: wtb nissan rear axle shims
Um, possibly. How thick do you need? And can you post a pic so I can confirm what I have is correct fitment?
i have no idea what size i need yet just trying to see if anyone has anything. I have pulled my axle out to find the bearing went nuclear and melted
i was too keen and didnt check preload before taking for a drive , my axle shaft and the bearing housing are now completely fucked so i need to find replacements for them then install another bearing and then i can check what size shim i need haha
