diff ratio/tyre size change
mudsurfv6
Post by mudsurfv6 »
hi guys
does anyone know of a calculation for changing diff ratios when tyre size changes to keep speedo the same.
apparently mine are 3.58, code A02A. 96 3.4 V6 auto surf, 31 inch factory tyres.
what ratio would I need to go to for 35 inch tyres?
Andrew 0272226292.
Ashohman
Re: diff ratio/tyre size change
Post by Ashohman »
Im running 35's on my lux running 4.88's at 100kms do about 2750rpm there are a few calculators on the net that you can stick your ratios and tyre size in and it will tell you what speed and rpm you will be doing.
Its all about trying to match what you have now so you still have the same torque and somewhat economy driven.
In doing this your motor needs to have enough power to turn em also so take that into account.
drive it ...
Post by drive it ... »
From 31's a 35 is just under 13% bigger rolling diameter so to keep factory gearing 13% bigger diff is 4.05 or whatever the closest you get to that.
BlakeNZ
Post by BlakeNZ »
4.1 would be the closest.
the basis of the maths is that the 35" tire has a height and circumference 13% bigger than the 31" tire. (35 divided by 31 = 1.129, hence 113% of 31")
so we need to adjust your ratio by 13%. In this case, we need a lower ratio(numerically higher) to compensate for your higher gearing created by the taller tires. So 3.58 ratio times 1.129 is 4.04 ratio(hence my thinking the 4.1 is the closest)
mudsurfv6
Post by mudsurfv6 »
thanks for that
Andrew 0272226292.
Return to “Tyres”
