I'm dreading having to get another later axle for parts availability as I have just done a cut and turn and sua conversion to the case
4wdstuff wrote:Hi, I can help with axles, CV's and Drive Flanges.
Also thinking that if you are going to run 35" probably want to upgrade brakes to discs.
diogenese wrote:Well after all I got a late model front axle with disk brakes and cut and welded that instead, it had good bearings, kingpins and aisin hubs.
It is getting converted to power rack and pinion steering too
