12th-13th sept.
Timmy511
12th-13th sept.
Post by Timmy511 »
Nearly there.....
catalystracing
Re: 12th-13th sept.
Post by catalystracing »
Pulled my fan clutch apart and re-filled with silicon, easy to do and should be done every 100,000ks so Im informed.
The old silicon was almost non existent and was very thick and burnt looking :shock: New tube was $31 from BNT
Took a bit to flush out as nothing really dissolves silicon.
Flushed radiator while at at.
Smurf
Re: 12th-13th sept.
Post by Smurf »
catalystracing wrote:Pulled my fan clutch apart and re-filled with silicon, easy to do and should be done every 100,000ks so Im informed.
The Toyota stuff is that colour new.
KIWI_TERRANO
Re: 12th-13th sept.
Post by KIWI_TERRANO »
Bolted my spot lights on, instailed reverse camera then went for hunt sunday and lost my canopy.... Snapped all the fibreglass flat edge that you use to bolt it down, hopefully insurance will cover it
catalystracing
Re: 12th-13th sept.
Thanks smurf, I was wondering how it would get so hot as to change color, Cheers.
tirantious
Re: 12th-13th sept.
Post by tirantious »
took out my old rotten radiator and replaced it with a shiny new one flushed the entire system while i was at it. then i bogged up some holes where the arieal used to live and dealt to some minor surface rust.
l200 with not a straight panel on it
Sheepy
Re: 12th-13th sept.
Post by Sheepy »
Removed the aircon system, minus the pump. Ill start on plumbing the AC to Air Compressor later in the week.
Twodiffs
Re: 12th-13th sept.
Post by Twodiffs »
Best place to get the Toyota stuff is Australia - $11.80 per 18ml bottle, I bought 6 when I was there recently.
