Wtd Landrover discover 1 transfer box
muddyplumber
Spring Free
Post by muddyplumber »
I'm after a transfer box to suit a Landrover disco one.Mine seems to be prety munted.
Cheers Rich
Ralfie
Re: Wtd Landrover discover 1 transfer box
Post by Ralfie »
muddyplumber wrote:I'm after a transfer box to suit a Landrover disco one.Mine seems to be prety munted.
Cheers Rich
are you wanting a 1.2 ratio or the 1.4 ratio?
What diff ratios did you use when converting diffs? Given you have the 35's tyres you might be better off with a 1.4 from a Defender rather than the 1.2 from Discovery.
muddyplumber
Spring Free
Turns out its a Defender 1.6 high ratio box.Im after a centre diff from a disco box now
Ralfie
Post by Ralfie »
muddyplumber wrote:Turns out its a Defender 1.6 high ratio box.Im after a centre diff from a disco box now
1.6:1 is a lower ratio box and is only from the Land Rover 110 4 cylinder models 84 to around 89-90. Seldom is it found in a Defender.
A discovery 1.2:1 is the 'higher' ratio as Discovery (and Range Rover) used smaller wheels so was geared higher for road.
The 1.4:1 ratio is what was used in 90's, 110's and Defenders through to 2007.
In all those transfer cases the low ratio is the same and the number reference (such as 1.6:1) only refers to the high range or road.
muddyplumber
Spring Free
Thanks for the info mate, so since the centre diff is stuffed from what I've been told. what are my options on fixing,repairing or replacing it with?cheers Rich
Ralfie
Post by Ralfie »
If it was mine, I would be looking for a replacement transfer case in the ratio I required.
Too much trouble setting up centre diff and gears to make it worth repairing unless you can't find the box you require.
But if you want to opt for the 1.2:1 then they are from RRC and Discovery 1 and are generally readily available.
Its the 1.4:1 and more so the 1.6:1 that are harder to find, therefore cost more.
Just remember once back together to engage that centre diff lock as soon as you venture off road. It is small and you are running very large tyres.
