We have just had a shipment of adjustable rear upper arms and +16 rear lower arms ,
$399 for a pair ! , If you have done a lift on your Patrol/Safari chances are your pinione inclination angle is wrong ,
With these arms you can correct it so it works harmonically with the output shaft which will increase uj , slip joint and pinion bearing life ,
Contact Trundles Automotive ltd
(06) 75 27 952 ,
Patrol Adjustable rear upper and extended rear lower arms
- Attachments
- adjustable rear uppers.png (28.07 KiB) Viewed 534 times
Re: Patrol Adjustable rear upper and extended rear lower arm
Here is a picture explaning what there purpose is
- Attachments
- drive shaft vibration.jpg (13.96 KiB) Viewed 532 times
