Nissan VH45 runners wanted.
- Checkerhead
OK not 4wd parts but hey...
I need the four corner runners that go between the block and the plenum, that the injectors mount into.
They have two different types. Some have about a 30mm odd diameter rubber that mounts the injector. Some use a smaller diameter rubber (maybe 20mm). I need the ones that use the smaller rubber.
So who has some VH45 parts? or knows someone?
Cheers.
Arron.
Cheers.
Arron.
Re: Nissan VH45 runners wanted.
what is the engine serial or if you know what model and year the engine came from or is in?
- Checkerhead
Good question.
The engine I have will have the wrong runners associated with it. So serial probably wont help.
It's currently sitting in a Safari so that won't help.
They are originally in Nissan Infinity's (Q45) from 1990 to 1996.
I believe that I am after runners from the last few years, but I really do not know for sure.
I will do some research.
well we can narrow it down some more the timing chain guide is it plastic/nylon or metal?
Does it have Vairable timing or not
is the alternator top mounted or not?
1990 to 93 had equal length runners and twin circle intake ports
94/95 had oval intake ports and revised injectors.
96 had no VTC
96 had no VTC
- Checkerhead
Well you know your stuff. (not the first time you have proved it of course)
Am told it has a metal timing chain guide. But I don't know if that is standard or has been replaced due to the known weakness.
It does have VTC and has/had twin circle equal length runners.
Based on what you have said I guess I need the 94/95 runners. That is assuming the 90-93 runners are interchangeable with the 94/95, except that the injector mounting is different?
- Checkerhead
Will try to find time on the weekend to pull it apart a bit and get photos of what I need.
Oh forgot, no idea where Alt was originally mounted. (I bought a part done project)
Arron.
Arron.
- Checkerhead
Just pulled them off.
Can confirm I need the 94/95 runners with the ovel port.
I currently have the 90/93 siamese runners.
Will try to uplaod pics tonight.
Arron.
Arron.
- Checkerhead
Thought I had a lead but it has dead-ended.
Does anyone know anyone who is using/has used VH45 engines that I w=could hit up to see if they have parts?
Any help or leads much appreciated.
- Bush Crasher
I've blown up a couple , got oval and Siamese runners I'm pretty sure I didn't scrap them , they at my brothers place under the hoarding pile , I'll check it out this weekend , keep your eye on this forum , I should have the complete intake manifolds as well
- Checkerhead
Bro! I would be stoked if you have some!
Will keep an eye on this but flick me a text on 027 278 2556 if you want if you have any.
Cheers.
Arron.
Cheers.
Arron.
- Checkerhead
And if you do have them, bring them with you and dream up a price (I'm a poor student now days but am obviously willing to pay)
- Bush Crasher
Will do , be looking on sat
- Bush Crasher
Ok so I found the intake manifolds , heads and blocks but no runners , there is a lot crap to dig through and it looks promising so I'm looking again on sunday
- Checkerhead
Thanks bro. Fingers crossed.
- Bush Crasher
bad news after an hour or so could only find one runner and its damaged , sorry dude.
- Checkerhead
Sweet as. Thanks for trying. Much appreciated.
