off so far
hub lid spring and gear
nuts and cone washers holding hub body
snap ring on end of drive shaft
hub body moves away about 1-2cm then stops
what am i missing?
asin(spelling) brand of hubs
jumper wrote:snap ring on end of drive shaft
wopass wrote:probably the groove where the circlip goes on the end of the shaft may have a bruise on it making the splines bind up in the hub as it comes up to it
