R50 rev counter and speedo flicking on and off...
Posted: Wed Sep 24, 2014 2:00 pm
by The Green Machine
Anyone experienced this? Both going while driving then all of a sudden go dead, then come back on later?! An electrical issue I presume. I have checked the fuses - all OK.
Re: R50 rev counter and speedo flicking on and off...
Posted: Wed Sep 24, 2014 10:07 pm
by mud_slinger
could be a loose connection in the plug or a dry solder joint on back of speedo cluster
Posted: Thu Sep 25, 2014 7:41 am
by ChurchurDan
Do they both stop together?
And do you have an analogue odometer or a digital one? The digital odometer clusters are more prone to complete failure.
Posted: Thu Sep 25, 2014 8:27 am
ChurchurDan wrote:Do they both stop together?
Yes - both stop together, then go again. Both are analogue.
Thanks
Posted: Thu Sep 25, 2014 11:27 am
The Green Machine wrote:ChurchurDan wrote:Do they both stop together?
Thanks
Oh - the odometer is digital - that doesn't stop! (unfortunately)
Posted: Thu Sep 25, 2014 5:35 pm
by slide
mud_slinger wrote:dry solder joint on back of speedo cluster
Quite likely to be this
Posted: Thu Sep 25, 2014 6:05 pm
by ChurchurDan
Pull the cluster out and take the speedo out of it and check for dry soldered joints on the circuit board or get it repaired by an instrument repair shop before it dies completely. When it totally dies the odo will go to 9999999 and all gauges will stop.
