private messages
Having problems. Check in here for answers, failing that post your problem.
Petemcc
private messages
Post by Petemcc »
Do these still pop up when you get one in your inbox? Or is the only way to know to go into the user control panel?
TJ
Re: private messages
Post by TJ »
There is a notification up on the top.
Swamped
Post by Swamped »
i started receiving email notifications again :)
Big
Post by Big »
Petemcc wrote:Do these still pop up when you get one in your inbox? Or is the only way to know to go into the user control panel?
yip you get a pop up window.. but you might have missed it..
Petemcc
Post by Petemcc »
sorted. Cheers
85bj71
Post by 85bj71 »
am I stupid or can I no longer find "private messages" with this new web lay out?
BlakeNZ
Post by BlakeNZ »
Na you aren't stupid. They have done their best to hide Private messages from us.
You need to click on "user control Panel" (top left corner)
then hover the arrow on "overview" button.
then from the drop down list, select "private messages" at which point a blank message appears, ready for you to compose a private message.
At which point you then hover over "compose message", which gives you another drop down list, at which point you can select "INBOX" !
Very laborious, and definitely not self explanatory.
zukmeista
Post by zukmeista »
BlakeNZ wrote:Na you aren't stupid. They have done their best to hide Private messages from us.
Can you show us the awesome forum that you run then please? I think the people running this one do an awesome job, and I would think a lot of people wouldn't be happy if it were to disappear so maybe try helpful suggestions rather than just having a moan?
BlakeNZ
Post by BlakeNZ »
I agree with you, they do do a fantastic job.
However, i feel every statement i've made is factual.(apart from suggesting they have done their best to hide the Private messages.)
On the the previous forum(ie prior to the change to .kiwi) the private messages were easy to access and very obvious.
Obviously the changeover has forced the administrators to use this new , very poor, system. Naturally, I thought this was a teething problem, so haven't criticised it at all, until today.
BlakeNZ
Post by BlakeNZ »
And while you(zukmeista) see only my criticism, the bulk of my post was actually info that was helping a fellow member,which i try to do often.
slide
Post by slide »
BlakeNZ wrote:And while you(zukmeista) see only my criticism, the bulk of my post was actually info that was helping a fellow member,which i try to do often.
Need the "like post" button again. I'm sure this post would get a few
mike
Last minute Mike
Post by mike »
Ill try and get some linking into these parts. This part of the board is pretty shit.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
Big
Post by Big »
mike wrote:Ill try and get some linking into these parts. This part of the board is pretty shit.
Maybe a new skin would help? or give more options..?
lax2wlg
Post by lax2wlg »
Yeah it is laborious.
Also I noticed the egosearch feature has disappeared. That was a useful feature for quickly locating previously posted tech information/pictures of naked Thai chicks etc.
Return to “Having problems?”
