Hilux/cruiser calliper pistons
lilpigzuk
Tiger Balm
Post by lilpigzuk »
Anyone got access to/sell new pistons to suit yota calipers? 2 x large, 2 x small per calliper. Needing to do both front in the near future and no doubt the rear 4 pots will be the same :lol: :cry:
Prices locally a little up there and for what I pay for rover pistons yota stuff sure as hell ain't cheap in comparison!!
mudlva
Re: Hilux/cruiser calliper pistons
Post by mudlva »
did you try don kyatts?
niblik
Post by niblik »
BNT bud..
rokhound
Post by rokhound »
lilpigzuk wrote:Prices locally a little up there and for what I pay for rover pistons yota stuff sure as hell ain't cheap in comparison!!
That has a lot to do with the amount sold dude. Yota stuff is mwade to last wong time :lol:
A couple of sellers on TM from Aussie sell rebuild kits prices look ok for some items not sure what the quality is like
callum007
Post by callum007 »
like they said. I got some at BNT a while back. I use http://www.onlineautoparts.com.au for odds and sods recently and have been good to deal with
smurf182
Post by smurf182 »
Got a pair of LN106 calipers for 295NZD from onlineautoparts.com.au. However had a quick look just now and the price has gone up to 325NZD.
BNT wanted quite a bit more than this
If you are interested in a small upgrade, the LN106 caliper with 4x 42.85mm pistons will fit in place of the Cruiser caliper that has 2x 42.85mm and 2x 33.93mm pistons, with a little trimming of the dust shield.
derk
Post by derk »
smurf182 wrote:If you are interested in a small upgrade, the LN106 caliper with 4x 42.85mm pistons will fit in place of the Cruiser caliper that has 2x 42.85mm and 2x 33.93mm pistons, with a little trimming of the dust shield.
and a bit of grinding on the calliper cooling fins unless you use a spacer the calliper's are a bit wider than the old 2 big piston/2 small piston ones most rims will fowl on them when you upgrade :D
soulja-on
Post by soulja-on »
Not sure if this helps, but i have a pair of front callipers and rotors from a kun26r hilux that i would sell if you were interested. Only just removed them over the weekend.
Flick me a PM if you wanted to yarn more about it.
