hydraulic winch
Posted: Tue Sep 30, 2014 7:29 pm
by noexitroad
so I am thinking about a budget hydraulic winch for my disco 1 (3.9 v8) bush truck
is there a pto kit for an lt230 transfer case to drive an hydraulic pump ( I think I can get a pump easy enough)
there seems to be lots of ideas on the web but has anybody actually done this sort of thing successfully??
Re: hydraulic winch
Posted: Tue Sep 30, 2014 8:38 pm
by RRS
It would be better to run the pump off the front of the motor with a belt and electric clutch.
Re: hydraulic winch
Posted: Tue Sep 30, 2014 8:39 pm
by Ralfie
noexitroad wrote:so I am thinking about a budget hydraulic winch for my disco 1 (3.9 v8) bush truck
been done many times.
But not popular in NZ due to cost.
Maxidrive in Aussie had a nice set up for the LT230 but unfortunately Mal retired closing the business.
UK would be good place to start.
Re: hydraulic winch
Posted: Tue Sep 30, 2014 8:55 pm
by derk
have a read here mate this is a good overview
viewtopic.php?t=23707 unless your in the industry and can steal everything from work "Budget" doesn't come into the equation when talking hydraulic winches
Re: hydraulic winch
Posted: Wed Oct 01, 2014 6:17 am
by mudlva
Hydraulics equals flow and pressure.
You can get flow off a v belt but any form of pressure can be a challange.
That said it is possible.
Pto either sprocket drive off the front or back is way of the engine/transmission unit is a lot easier to achieve pressure and flow combined.
Hydraulic will never be as cheap as a electic setup. But set up well they pull as hard as a pto but are user friendly as electric. Also by the use of pressure relief valves you can look after the rope a lot better
Re: hydraulic winch
Posted: Wed Oct 01, 2014 4:28 pm
by 4WDbits
At the risk of hijacking the thread, my hydraulic winch is for sale
http://www.4wdbits.co.nz/ProductDetailsU.aspx?productID=5097
Re: hydraulic winch
Posted: Wed Oct 01, 2014 7:05 pm
by klompy
Give Marcel at Mamaku 4X4 a ring hes done this before and knows what works.
Re: hydraulic winch
Posted: Wed Oct 01, 2014 7:13 pm
by noexitroad
thanks for your replies.
that thread that mark did is bang on the info I am after too.
unfortunately the images do not come through.
I might pm him if he is still about on here?
I am working for an engineering company that does hydraulics so although it's not my forte, there is an opportunity to buy at reduced prices through work.
Re: hydraulic winch
Posted: Wed Oct 01, 2014 7:18 pm
by bryan.daley
I've done this a few times before. Once with original land rover pto pump and worm winch which was brilliant. Expensive even second hand.
Also used maxi-drive pto pump into a low mount which was ok but a lot slower.
Prefer electric now. Easier and cheaper and I do shinny 4x4'ing now.
Re: hydraulic winch
Posted: Thu Oct 02, 2014 4:48 pm
by NOBDY
Red winch make kits for landie's. complete set up, bolt on. My mate has just brought one of the flash 2 speed set up's from Phil at force4. We are hoping to have it running for NZ1 in November on a 90.
google red winch, and you will find them easily enough. Real popular in England, and phil was good to deal with also.
Re: hydraulic winch
Posted: Thu Oct 02, 2014 5:54 pm
by noexitroad
I would be pretty keen to know how it goes, keep us informed.
a straight bolt on to an lt230 is the way to go I reckon, at least it's a proven product before we start and it looks pretty compact. are you buying the winch as well or just the pump?
Re: hydraulic winch
Posted: Thu Oct 02, 2014 7:53 pm
by Batfastard
My 2 cents worth is if you dont have at least 3k to spend ,you need to go down another track .
Re: hydraulic winch
Posted: Thu Oct 02, 2014 8:20 pm
by monstr
Batfastard wrote:My 2 cents worth is if you dont have at least 3k to spend ,you need to go down another track .
and to add to this for 3k your going to get a pretty average set up ,wont be up to comp specs, to get a good strong fast winch expect to spend 8/9 k plus
Re: hydraulic winch
Posted: Thu Oct 02, 2014 9:30 pm
by noexitroad
for $3k i could get a top electric winch plus biggest battery plus uprated alternator and maybe have some change then....
Re: hydraulic winch
Posted: Fri Oct 03, 2014 6:14 am
by mudlva
noexitroad wrote:for $3k i could get a top electric winch plus biggest battery plus uprated alternator and maybe have some change then....
Im picking you will be going electric then
Re: hydraulic winch
Posted: Fri Oct 03, 2014 6:30 am
by noexitroad
hurry up and get your one going and convince me otherwise rohan
Re: hydraulic winch
Posted: Fri Oct 03, 2014 11:37 am
by mudlva
noexitroad wrote:hurry up and get your one going and convince me otherwise rohan
yea yea yea i hear ya
