94 Mistral 2.7TD fluids
Disco Gofer
Hi guys, any one know or know the web page to get all the fluid types and levers for the 2.7 Mistral? I want to change the fluids on a friend's Nissan from the diffs to the auto box, trans box, engine and rad (rad volume no a problem obviously).
Re: 94 Mistral 2.7TD fluids
engine without filter change 5.5 litres API CE ACEA B2-96 (CCMC PD1) D5
with filter 6.2
Cooling system 10 litres/ reservior .6 litres mixture premixed 50%/ concentrate 30%
Manual gearbox FS5W71C 3.5 litres /FS5R30A 3.6 litres API-GL4*
Automatic transmission RE4R01A Genuine Nissan ATF Fluid or eqivalent 8.5 litres
Transfer case TX10A 2.3 litres API GL-4
Differential oil R180A 1.3 litres API GL-5/ R200A 1.5 litres API GL-5**
H233B(LSD) 2.8 litres API GL-5 and or SAE 80W-90 approved for nissan LSD
Power steering fluid 1 litre DEXRON
Brake and clutch DOT 4 +
Multipurpose grease NLGI No.2 (lithium soap based)
*Refer to notice issued. (FS5W71C) Potential underfilling leading to premature failure. Add a further 1.5 litres via the gear lever.
** Fitted to Post june 1998 SLE 2.7 and 3.0 diesel
with filter 6.2
Disco Gofer
Crash bandicoot wrote:engine without filter change 5.5 litres API CE ACEA B2-96 (CCMC PD1) D5
with filter 6.2
Crickey that's awesome! Thanks so much>
that's the official specs...in saying that i changed my rear diff oil recently in my 98 facelift and managed to get just shy of 4 litres into it...probably explains why i get the occasional drip on the fire wall from the diff breather.
Disco Gofer
haha well a drip from a breather may just indicate a bit too much..............
