can not get surf into 4wd my add actuator is holding vacuum switched the vacuum hoses around did not engage took off the add actuator moving ok and when i pushed the button in side to engage 4wd the add solenoilds (vsv) as got vacuum but when i push it to come out of 4wd the vacuum on the vsv as not moved still on the same side.
hope some one can help
andrew\
surf will not go into 4wd
- jonossiksilvia
Re: surf will not go into 4wd
What is the 4wd light on the dash doing? is it coming on or flashing and beeping or just staying off? have your tried putting into low ranch and getting 4wd to engage that way (this way will only work if the low range sensor still connected)? Is the 4wd engage motor working? Manually engage the front actuator by hand - does this help?
And welcome to ore
And welcome to ore
Hi the light does not come on could it be the 4wd computer ? when i push the button i can here a click but the vacuum on the add solenoild stays on the same side when i push the button out .It should go from oneside to the other.
tried putting it into low ranch still know go. could the add switch thats on the add actuator be faulty ? did water blast under it last week may be something happen then? i had it in 4wd 3 weeks ago
thanks
andrew
thanks
andrew
Are you sure it isn't the motor on the back of the transfer case? Your front diff might be engaging but not the transfer case?
thanks. Had water in transfer case motor from a split in hose cleaned a up now have got 4wd back
Thanks
Andrew
Thanks
Andrew
