Nissan terrano cooling
Posted: Sun Oct 12, 2014 8:27 pm
by RoryOconnor
Hey guys, im new to 4x4ing and i have a slight issue with my nissan terrano i bought, the previous owner for whatever reason took off the clutch fan and put in a 10 inch electric fan. Its overheated on me going on like a 50 minute drive, do you have any suggestions on what i should do, I may just grind out the electric fan and put a clutch fan back in or do you guys have any other suggestions.
I will first water blast the rad then flush it, and see how i go (td27 non turb engine)
cheers guys [nissan terrano 1987 td27]
Re: Nissan terrano cooling
by RoryOconnor
Posted: Sun Oct 12, 2014 9:39 pm
by Ant
First thing is check the fan is working correctly, and drawing air through the entire radiator. The cowling/shroud needs to be working correctly and be the right shape.
Hold a rag to the radiator with the fan running, it should suck the rag quite hard into the radiator, do this in each corner and edge of the radiator and make sure it does the same thing. No point in moving heaps of air through just part of the radiator
After that check the thermostat is working, water pump is moving enough water and you have no air locks. Might be a good time to check your radiator is flowing to, take it to a radiator shop and get them to rod it.
Posted: Mon Oct 13, 2014 3:16 pm
by RoryOconnor
Thanks for the info, i did the rag test and it was pulling thought on the fan side but yea,
Here is a picture of the radiator
I changed the coolant today but i havnt driven it for long as it has a green sticker
Posted: Mon Oct 13, 2014 3:40 pm
by derk
RoryOconnor wrote:Here is a picture of the radiator
might just be the picture but it looks like its all blocked up with mud or some sort of shit stopping any air getting through it :D
Posted: Mon Oct 13, 2014 4:21 pm
by RoryOconnor
Hahaha yea i do need to clean it, but it was doing this before i got it all muddie
Posted: Mon Oct 13, 2014 7:33 pm
by Crash bandicoot
seriously? how is that supposed to stay cold.
get the factory fan and shroud back on there.
Posted: Mon Oct 13, 2014 8:14 pm
by Ant
Yeah thats your problem, really need to get the air blowing through the entire radiator.
Get a shroud put on and get it to a radiator shop for a good clean on the inside to. It will set you back about 150 at the most
You can make a shroud if you tight on chash or go downcto the wreckers and get one that is close enough and make it fit.
Posted: Mon Oct 13, 2014 10:01 pm
by centralnavara
I agree with the lads above and if its been getting hot it could well have damaged the thermostats life span considerably so replace it well your on the job. none turbo TD27s don't normally build up bugger all heat.
Posted: Tue Oct 14, 2014 6:55 pm
by RoryOconnor
Cheers for all the advice guys, ill take out and waterblast the rad and put the clutch fan back in
