Chiping a 70 series Prado KZJ
oldblue
Post by oldblue »
Hi, Has anyone fitted a chip to a 70 series Prado kzj-7# ? No I don't want to buy a bigger truck, just want a bit more power for when I tow a caravan. Is there one that will fit with out to much hassle.
imsohi
Re: Chiping a 70 series Prado KZJ
Post by imsohi »
Have a talk to Scotty Newport and newport engineering i no he has or had one in his 1kz surf.
$200 chips from Germany will find the link
have you done the turbo dump pipe and bigger exhaust as well?
oldblue
Post by oldblue »
Yep! Done all that, Dump pipe, Larger Exhaust pipe, Blocked off the Exhaust return thingy. :)
hello24 wrote:
i am running power chip from no limit tuning with adjustable fuel delivery and running the standard fuel pump, its delivering more then enough fuel to support whatever mods you are going to do i am running. 2.5" exhaust, front mount intercooler, water meth injection and 20psi and have a huge adjustablity in the chip i am only on setting 3 of 7 settings so have alot more room for more power if i ever decide to get a larger turbo...... i defently recommend the ecu chip but only if you have a few mods as they do deliver alot more fuel. i wouldnt use one on a standard setup alone... and will completly change the feel of the truck. didnt think i would ever see this power from a 3l diesel, having no problem smoking it up in the dry now :twisted:
http://www.no-limit-tuning.com/
stinky
House Hubby
Post by stinky »
Somrthing new to add to my list
:D
____________________________
Martin
http://www.wtbs.co.nz
