Chiping a 70 series Prado KZJ
Posted: Wed Oct 15, 2014 3:57 pm
by oldblue
Hi, Has anyone fitted a chip to a 70 series Prado kzj-7# ? No I don't want to buy a bigger truck, just want a bit more power for when I tow a caravan. Is there one that will fit with out to much hassle.
Re: Chiping a 70 series Prado KZJ
Posted: Wed Oct 15, 2014 4:24 pm
by imsohi
Have a talk to Scotty Newport and newport engineering i no he has or had one in his 1kz surf.
Posted: Wed Oct 15, 2014 4:39 pm
by Jerry
$200 chips from Germany will find the link
have you done the turbo dump pipe and bigger exhaust as well?
Posted: Wed Oct 15, 2014 4:46 pm
by oldblue
Yep! Done all that, Dump pipe, Larger Exhaust pipe, Blocked off the Exhaust return thingy.
Posted: Wed Oct 15, 2014 4:51 pm
by Jerry
hello24 wrote:
i am running power chip from no limit tuning with adjustable fuel delivery and running the standard fuel pump, its delivering more then enough fuel to support whatever mods you are going to do i am running. 2.5" exhaust, front mount intercooler, water meth injection and 20psi and have a huge adjustablity in the chip i am only on setting 3 of 7 settings so have alot more room for more power if i ever decide to get a larger turbo...... i defently recommend the ecu chip but only if you have a few mods as they do deliver alot more fuel. i wouldnt use one on a standard setup alone... and will completly change the feel of the truck. didnt think i would ever see this power from a 3l diesel, having no problem smoking it up in the dry now
http://www.no-limit-tuning.com/
Posted: Wed Oct 15, 2014 5:03 pm
by stinky
Somrthing new to add to my list
