1KZ Coolant Bung In Head
Posted: Mon Oct 20, 2014 8:10 pm
by mudbugga
I'm fitting a coolant temp sensor (Auberins) to a mates KZJ95 Prado and thought of using the bung in the head to fit the sensor instead of a top hose adapter.
On the Surf's this port is used for a coolant hose to the throttle body, but on the Prado's it's blanked off with a bung.
Seems to have a tapered thread. Unusual size though. I don't have a pitch gauge at work to try.
Anyone know what the thread is?
Anyone used this coolant port before as a sensor placement?
The sensor that comes with the gauge that has been ordered is 1/8" NPT. Unsure if that is same size??? Thread seems a lot finer on the sensor in pics.
Maybe need an adapter???
Re: 1KZ Coolant Bung In Head
Posted: Tue Oct 21, 2014 4:35 pm
by imsohi
is this the bung behind the injector pump on the head? thread for that one is 1/8 bsp that's where i have my temp gauge works a treat
Posted: Tue Oct 21, 2014 5:55 pm
by stu_71
Imsohi, you are referring to this bung right?
Posted: Tue Oct 21, 2014 6:30 pm
by mudbugga
Definately not 1/8BSP.
Posted: Tue Oct 21, 2014 7:18 pm
by tallsam66
I too doubt it would be BSP .
Japs don't use British Standard Pipe Thread.
Posted: Tue Oct 21, 2014 7:36 pm
by nismo26
tallsam66 wrote: Japs don't use British Standard Pipe Thread.
My TD42 has factory BSP fittings in the block.
Posted: Tue Oct 21, 2014 8:56 pm
by mudbugga
Here's a pic of the bung. Sorry bad photo used my phone.
Posted: Tue Oct 21, 2014 8:57 pm
by mudbugga
Thread pitch also not metric 1, 1.25, or 1.5
Seems in between 1.25 and 1.5 though.
Posted: Wed Oct 22, 2014 7:50 am
by derk
if you take your bung down to enzed or one of those hose fitting places they should be able to match it up for you and probably sell you the fitting you need for your gauge
Posted: Wed Oct 22, 2014 6:38 pm
by mudbugga
derk wrote:if you take your bung down to enzed or one of those hose fitting places they should be able to match it up for you and probably sell you the fitting you need for your gauge
Yup, that's the plan now.
If nothing available off the shelf, we should be able to make something up.
Going to wait for the sensor to arrive before we get too carried away, just in case.
Posted: Wed Oct 22, 2014 7:03 pm
by derk
is that bung big enough to drill and tap a 1/8 NPT thread into it
Posted: Wed Oct 22, 2014 10:10 pm
by smurf182
tallsam66 wrote:I too doubt it would be BSP .
Oil pressure sender and other plugs on my 3B are 1/8BSP.
Weird maybe, but the 1/8BSP thread is common in Toyotas.
Posted: Thu Oct 23, 2014 5:19 am
by wjw
smurf182 wrote:tallsam66 wrote:I too doubt it would be BSP .
From trying to find sensors for various projects 1/8BSP is the most popular, real PITA sometimes
Posted: Thu Oct 23, 2014 8:43 pm
by mudbugga
BSP is usually universally used for oil fittings.
The coolant side of things is all over the place.
We may be able to drill and tap the bung. Will see when the sensor arrives and go from there.
Posted: Sat Nov 01, 2014 9:23 pm
by mudbugga
Local hydraulic supply store had a off the shelf adapter just perfect for the job.
