Chassis swap
Posted: Tue Oct 21, 2014 4:32 pm
by Hiluxer
Ok so i have cracked my ln107 chassis and want to replace it with a 106 one is this a relatively swap seeming as everything is the same apart from 107 being ifs? If i do decide to go with it can i get a dead chassis and put my live 107 body on it and get it certed for the dead chassis? Any tips if i decide to do it etc, cheers all
Re: Chassis swap
Posted: Tue Oct 21, 2014 6:13 pm
by Crash bandicoot
you will need cert, like for like swap can be seen as a repair or replacement of worn parts but if your original is live axle and the replacement independent may raise some issues.
Re: Chassis swap
Posted: Tue Oct 21, 2014 8:37 pm
by Hiluxer
The original is independent and the one im swapping to is beam axle, Im just not sure if all the paperwork to make it legal again is guna be worth it and i need to find a live plated chassis etc.
Re: Chassis swap
Posted: Wed Oct 22, 2014 6:09 am
by klompy
Talk to LTSA or your local certifier,chassis will have to have a history and you will need to have proof of ownership but needs to be deregistered at time of recomplying.Body will bolt straight on but front drive shaft and steering shaft from column may be different.
