prado front radius arms wtd
mudsurfv6
Post by mudsurfv6 »
hi
I'm after both front radius arms for a 94 on KZJ prado.
prefer wellington wairarapa manawatu but could freight from elsewhere.
Andrew 0272226292.
De-Ranged
Re: prado front radius arms wtd
Post by De-Ranged »
I have a set of Landrover Disco front radius arms here that come with near new caster correction bushes... if your not brand specific
mudsurfv6
Post by mudsurfv6 »
was hoping to stay all Toyota, but will keep it in mind thanks
Andrew 0272226292.
kbushnz
Post by kbushnz »
Just be aware there are 2 different front arms in the playdohs..( rears for that matter)
While both have the same shape and location for the bushes the early ones are smaller/ thinner in the castings / steel.
The lighter ones bend easily on the trail.... Well they do in our winch challenge truck lol.....
mudsurfv6
Post by mudsurfv6 »
good to know that. is the difference 71 or 78? so I would need the 78s?
Andrew 0272226292.
kbushnz
Post by kbushnz »
The 2.4L powered trucks (LJ7*) have the thinner arms.
The 3.0L powered trucks (KZJ7*) have the thicker arms.
Thin front arms P/N 48610-60012
Thick front arms P/N 48610-60013
mudsurfv6
Post by mudsurfv6 »
thanks for that.
Andrew 0272226292.
Checkerhead
Post by Checkerhead »
Bro those arms are not the strongest. I bent both of mine and I don't even know how (don't know if they were thin or thick ones). Always carried spares to comp. Seeing as you are building from scratch, just use something stronger. Look at Pajero rear radius arms.
That's my two cents.
mudsurfv6
Post by mudsurfv6 »
Checkerhead wrote:Bro those arms are not the strongest. I bent both of mine and I don't even know how (don't know if they were thin or thick ones). Always carried spares to comp. Seeing as you are building from scratch, just use something stronger. Look at Pajero rear radius arms. That's my two cents.
I've found a prado diff cheap, its missing the radius arms though.
Andrew 0272226292.
oldblue
Post by oldblue »
They changed from thin to thick arms about 1994 on the KZJ 7#. My Prado is 1993 and it has thin arms.
mudsurfv6
Post by mudsurfv6 »
oldblue wrote:They changed from thin to thick arms about 1994 on the KZJ 7#. My Prado is 1993 and it has thin arms.
also good to know that thanks, have edited original posting again.
Andrew 0272226292.
jesse.woollett
Post by jesse.woollett »
hi ive got a set of front ones I was going to use in my rallhy truck but think im going to stick with the 3 link now. but there off a 91. :(
mudsurfv6
Post by mudsurfv6 »
jesse.woollett wrote:hi ive got a set of front ones I was going to use in my rallhy truck but think im going to stick with the 3 link now. but there off a 91.
where are you?
i'll keep it in mind and keep looking for thicker ones. thanks
Andrew 0272226292.
mudsurfv6
Post by mudsurfv6 »
still looking
Andrew 0272226292.
KIWI_TERRANO
Post by KIWI_TERRANO »
You in facebook? Look up 4wd canterbury and beyond there a guy selling a heap
sig
Jeep Jeep
Post by sig »
think I may have a pair in my lockup .not sure what model thou
mudsurfv6
Post by mudsurfv6 »
KIWI_TERRANO wrote:You in facebook?
no not on facebook.
KIWI_TERRANO wrote:4wd canterbury and beyond
any other way of contacting them?
sig wrote:think I may have a pair in my lockup .not sure what model thou
hopefully a pair of the stronger ones :) if so how much will you want?
I grew up in stokes valley.
Andrew 0272226292.
80 series front arms any good ??
mudsurfv6
Post by mudsurfv6 »
skid wrote:80 series front arms any good ??
not sure. do they attach to the prado diff the same? they are for 185 surf sas so be new mounts on chassis.
Andrew 0272226292.
Clint
Post by Clint »
X2... I bent mine (1991 LJ71) a few times.
Clint
UZJ71 Landcruiser
KTM 640
kbushnz
Post by kbushnz »
80 series ones won't fit in without some mods to get the caster right again....
mudsurfv6
Post by mudsurfv6 »
Clint wrote:I bent mine (1991 LJ71) a few times.
be the thinner/weaker ones? kzj stronger?
Clint wrote:Look at Pajero rear radius arms.
they don't attach to the prado diff the same by any chance do they?
safari arms attach to the prado diff in the same holes aye? are they stronger? someone said range rover ones are stronger & longer, do they attach the same?
De-Ranged wrote:I have a set of Landrover Disco front radius arms
are disco the same as RR?
Andrew 0272226292.
De-Ranged
Post by De-Ranged »
I won't say positively yes, as i don't have any RR ones but the chassis is so similar that I'd be surprised if there is any difference
sig
Jeep Jeep
Post by sig »
I run rangie front arms on my 40 and they have taken some serious abuse in the last 20 yrs. only thing I need to do now is put new bushes in them .much as I hate to say it the rangie arms are pretty bloody strong
mudsurfv6
Post by mudsurfv6 »
sig wrote:I run rangie front arms on my 40
and they would bolt onto a prado diff the same?
Andrew 0272226292.
mudzuki
Post by mudzuki »
Have full set of prado arms im no longer using, prety sure they are kzj78 ones
mudsurfv6
Post by mudsurfv6 »
zukmeista wrote:Found some yet? http://www.trademe.co.nz/motors/car-par ... 545074.htm
have asked about postage. thanks. be nice to find some a bit closer.
Andrew 0272226292.
