WTB: PTO universal BJ74
Heisenberg87
Post by Heisenberg87 »
Hey there
Am looking for Pto universal at the winch end on my BJ74.
derk
Re: WTB: PTO universal BJ74
Post by derk »
if you look under the winching section on the IH8mud forum there's a couple of pto threads listing all the universal part numbers and sizes, don't forget to sort out a handful of shear pins (hardened ramset nails or similar) the pins are only 4mm and break pretty easily generally when your burried in the shit trying to winch your arse out :D
Heisenberg87
Cheers Will have a look. Seems second hand universals are pretty rare. May have to fabricate something.
Clint
Post by Clint »
I have heard of quad bike driveshaft universals being used for PTO drives if that helps.
Clint
UZJ71 Landcruiser
KTM 640
mudmike
Post by mudmike »
which parts are you after? if you just after the universal to rebuild yours then available from repco. if its one of the toyota shaft parts have some spares if you say what you actually need.
Heisenberg87
I need the couplers that attach to the spline on the PTO drive shaft and the bush on the winch as well as the universal.
Heisenberg87
Bump
Big
Post by Big »
post a pic of exactly what ya want as I might have it here in bits.. Ta
Heisenberg87
here is the gap im trying to fill
Big
Post by Big »
Might have something in my bits.. as I don't use Toyota splines.. ill let ya know later during the week.. pretty sure ill have something.. will post a pic
Ta
