4d56t knocking/tapping noise after new rings and bearings
scruff123
Post by scruff123 »
any ideas on what this noise could be? has me stumped. have reset tappets, cracked injectors-slight decrease in noise but not shure if it just because the revs drop and it stutters wen only running on 3.
https://www.youtube.com/watch?v=Wizl0zQvaqs&list=UUiEufeFGBcIVor-sVIFp9fA
FORGE1
Re: 4d56t knocking/tapping noise after new rings and bearing
Post by FORGE1 »
At a guess I reckon it could be one of the injectors is stuffed. Do the old screw driver up to the ear on all of the, and see if that narrows it down bro.
wopass
Post by wopass »
not even goint to watch the vid but a real common one is
did you de lip the bore?
new rings in old bore will tick like a boss and probly wreck all the new rings you just put in.
just an idea
:mrgreen:
Crash bandicoot
Post by Crash bandicoot »
yep, also happens to the face of the head too, the very edge of the lip burs over normally on the driver's side of the cylinders for some reason too.
yael
Post by yael »
Did you get the correct thickness head gasket?
If you cant beat us Gingers, JOIN US!!
scruff123
Post by scruff123 »
Yup correct head gasket thickness used. It is a non turbo head on turbo block but shuldnt make a difference. And yes bores were given a de glaze. Nt shure if it was enough tho as bores were a bit scored and old pistons had dents in the top from something getting into the cylinders. Was just ment to be a cheap re ring. Not to worried. Will try the screwdriver test c if i can find exactly were its comming from.
Cheers guys
scruff123
Post by scruff123 »
It wouldnt be bearing clearances would it??? Hope not. Sounds like coming from top end not bottom
scruff123
Post by scruff123 »
would leaving the balancer shaft belt off cause this?
