Bighorn alternator upgrade.
For all Isuzu related topics
nivaman
Post by nivaman »
UBS69 3.1 td auto.
What bigger amperage alternator will fit (plug n play)?, I have read about a 110 amp alternator from an Isuzu truck may fit but am unsure which one and if it would actually fit?.
Would the alternator from a Pajero fit or are the feet and the plug different?.
evolution02
Re: Bighorn alternator upgrade.
Post by evolution02 »
From factory the early bighorns had a 50 amp alternator and then the later ones had an 80 amp one. Might pay to check what yours has
The 80 amp is a good alternator. Have attached a photo of the 80 amp
nivaman
Post by nivaman »
I have a 60 amp and would ideally like some reserve capacity, hence why I asked about the Isuzu truck alternator.
Mattman
Post by Mattman »
What are you running to need more than 60 amps?
My truck is fully loaded with two thermo fans, light bar, winch, gauges etc. I do have dual batteries tho.
Matt.
evolution02
You should def upgrade to the 80amp one then.
We don't fit the smaller ones anymore, just bang the bigger one on
Return to “Isuzu”
