i cant seem to get pics to load so this is the album link
http://s299.photobucket.com/user/NUTS_0 ... h%20basher
derk wrote:nice shaving but she's a bit of a grader blade with that bracing underneath now
Smurf wrote:derk wrote:nice shaving but she's a bit of a grader blade with that bracing underneath now
If you knew how he drove, then you'd know what the grader blade was for
well i went out with north cantabury 4wd club into the blackburn and seddonville most of them had safaris and some had diffs shaved and it did make a difference when i was watching them traverse different terrain ... personally i just did it cos i could and im only running 33 " mudders so drag my diff every where .. im also going to put lsd in front diff so yet to try it out but as smurf said im ruf on itCraydiver wrote:is the effort required for a diff shave on the safari really worth it?
ie does it really gain much?
I ask as I have saf and ive discovered my front diff has a small oil weep from a weld, and may need to strip to repair.
I was considering to get diff strengthened as well too but didn't think a diff shave achieved much.
tallsam66 wrote:I guess Nissans need all the help they can get to keep up with the Toyotas lol.
But seriously ... I hope you braced the diff as you were welding it to keep it from twisting from the heat of the welding.
fisho wrote:whats the next part of the bulldozer build when the front diff is finished?.
nuts wrote:fisho wrote:whats the next part of the bulldozer build when the front diff is finished?.
just organised carrier for lsd in the front and then going to do the factory difflock rear diff shave and strengthen![]()
Smurf wrote:nuts wrote:fisho wrote:whats the next part of the bulldozer build when the front diff is finished?.
Tracks being added last??
Crash bandicoot wrote:fisho wrote:whats the next part of the bulldozer build when the front diff is finished?.
the rear diff?...call that one the leveling bar?
