thort I had posted this, I must have not saved/posted....what ever
Anyway, my door hinges are worn and sloppy. I have some pins/bushes from ebay - Thailand.
Has anyone used these?
After I have removed the old pins, do I need to drill the hinge out for the bushes to fit?
If so.....by the time I removed the door, and unbolt the hinges, I may as well just fit new hinges.
Any advice?
D21 door hinges
Re: D21 door hinges
just swapped the top for bottom on mine as they wear opposite sides,
Re: D21 door hinges
All I used was cheapies too, I left the doors on and removed the front guards instead, easier to get to the hinge brackets
They run bushes from factory so you just knock the old ones out and push the new ones in, I think I used a nut bolt and couple of washers as a puller to make sure they went in square
Re: D21 door hinges
I had the same issue
$40 at zebra in manukau for some good ones! They have heaps of d21's in there at the moment with plenty of good parts!
