Jk body wobble
gordo
Jk body wobble
Post by gordo »
Just got this 2007 jk 2 door and when you are driving along the road it makes your head rock side to side it feels like the body and whole truck is moving ,does any one know what is making it do this
TJ
Re: Jk body wobble
Post by TJ »
Your tires could be out of round. Bad shocks. Bad motor mounts. Could be a number of things. How many kms on the clock?
tycho
Re: Jk body wobble
Post by tycho »
Anti sway bars disconnected? Back one should never need disconnecting. Other than that maybe check shocks.
gordo
Re: Jk body wobble
Post by gordo »
So far we have found the steering dampner stuffed and and so are the shocks
Would like to put about a 2 inch lift what type would give you a good ride ?
Thank for the help
tycho
Re: Jk body wobble
Post by tycho »
Lots of lift options but Old Man Emu do a nice tuned package set up for your rig dependent on body type, bars etc. don't be tempted to go for their heavy duty springs unless you are so heavy as to need them as this will just result in a stiff three inch lift. I've been running OME for a few years now and no probs, just swapped out front springs to HD when I put the bar and winch on. OME do a JK steering dampener now also. Pays to relocate it above the tie rod to get it up out of harms way. Check the relocation bracket from Double Black Offroad dotcom
tycho
Re: Jk body wobble
Post by tycho »
Just incase you are worried that a 2 inch OME lift won't give you enough flex these were taken today :)
Return to “Jeep”
