topless 40 series seat belt mounts
Posted: Sat Dec 13, 2014 5:03 pm
by Heath
So what are you guys with rag tops using for the upper seatbelt mounts?
I am looking at the options for perhaps making up a rag top for my hj45 ute, but the seatbelt upper mounts are in the rear section of the cab which I want to take off. Might have to cut and weld my rust filled spare cab back so I can use the belt mounts.
Any pics would be greatly appreciated.
Heath
Re: topless 40 series seat belt mounts
Posted: Sat Dec 13, 2014 5:12 pm
by derk
when you take the roof off you mount the seat belts on the roll cage, they usually make you weld the seatbelt mounts on the back of the B hoop so theres no forward facing projections to smack your scone on
, if your driving around in your cruiser with no roof and no cage or b hoop your a brave man
Posted: Sat Dec 13, 2014 11:32 pm
by curly12
derk wrote:when you take the roof off you mount the seat belts on the roll cage, they usually make you weld the seatbelt mounts on the back of the B hoop so theres no forward facing projections to smack your scone on
x2
Posted: Sun Dec 14, 2014 6:07 pm
by Heath
Problem with a cage as such is that I dont want the backstays going out the back of the cab and into the tray. I want to be able to put the top on without removing a cage and messing around with the belt mounts.
I will stick with a hard top rather than drive topless without belts and a bar. Was trying to get some ideas to show the certifier so I could maybe get him to see things my way.
Anyone got a 45 series ute with a canvas top?
Posted: Sun Dec 14, 2014 7:11 pm
by skid
How old is she ??
Does it require 3 point or is a lap belt suffice for its age ?
Posted: Sun Dec 14, 2014 9:17 pm
by Heath
79 so it has 3 point belts.
Seat belt restraint bar (or whatever they are called) have specs that sound a lot like a roll cage.
Might just have to find pics of 45s with rag tops and hope for an internal shot.
