What might be the cause of the clunk when selecting reverse.
Seems more pronounced when truck is warmed up.
Done 280K.
Pretty normal for this many clicks?
Or ugly times a coming?
D1.
Cheerz
Tranny clunk
Re: Tranny clunk
Totally normal, nothing to worry about
Re: Tranny clunk
Thanx lax.
That`s a relief.
Have a G8 Xmas cobber.
That`s a relief.
Disco Gofer
Re: Tranny clunk
My Son's 95 V8 does the same into reverse from neutral and its normal for the mileage, just a bit of free play in the transfer box. Oil is thinner when hot so resistance is reduced.
- Team Tonka
Re: Tranny clunk
Can also be a warning that the spider gear cross pin is working its way through the carrier. Caused by excessive wheelspin usually. Also some models had a rubber doughnut connection between prop and diff and these crap out too. See how much free play is in the diff. Any more than 1/4 turn and something is on its way out.
May the force be with you.
Re: Tranny clunk
It can also be the A frame Ball joint starting to flog out a bit.
Re: Tranny clunk
Cheerz for that fellas.
May try the engine and tranny rubber mounts too.
