SJ Transfer ratios
Posted: Sun Dec 21, 2014 3:23 pm
Does anyone have a quick fire way to work out weather I have a rocklobster box in my SJ or not? Like if I turn the prop the output shafts fhould turn X times? I don't have a working speedo before anyone suggests it should do X speed at X rpm
It seems to drive fine around the section in High, and low feels much lower than it normally would but I've never owned an SJ before, and this is on 31" tyres which I thought should be almost unusable in high.
Edit..after deciding to have a further read of material I found, the rocklobster box is 4.16 in low, so I assume if I were to turn gearbox output it should turn around 4 times for every 1 turn of the driveshafts correct? And I would hazard a guess that a standard transfer is more like a 2:1 ratio in low?
