25th-28th December
Posted: Sat Dec 27, 2014 10:02 pm
by Filthy4x4
Cant beat a 4 day weekend :mrgreen:
Had that jolly fat man turn up a day early and create more work for me, right before christmas too :twisted:
Out the back of his sleigh fell 4 x Mickey Thompson 35s and a 3" EFS lift kit :shock: Stoked!! til I read the name tag and they were for the mrs :lol: :lol:
I also got around to installing the PRS I had bought on special just before we went on holiday.
Plenty of brownie points earnt :mrgreen: :mrgreen:
Re: 25th-28th December
Posted: Sun Dec 28, 2014 5:57 am
by Mattman
Vice grips are an unusual electrical install tool haha!
Put the radiator back in the truck after finally getting all the Rallywoods mud out of it and took my beadlock rims apart. 160 bolts and only broke 4.
One of the rims has nearly all the threads stripped and nuts have been used on longer bolts and one of the rings is quite bent.
What do people do with stripped threads? Can you tap and run 7mm? Doesn't look to be enough meat to go to 8mm. Are nuts okay? What torque do the bolts need to be done up to?
Matt
Posted: Sun Dec 28, 2014 6:40 am
by mudlva
grade 8 bolts and nuts are fine
people strip the threads due to being ti heavy handed when doing them up.
my process is to nip the next bolt slightly more then the previous and do 4 to 5 rotations of the bead. they all end up nice and tight with a lot less stress on the fastener then say 1 to 2 rotations
takes more time but worth it in the long run
Posted: Sun Dec 28, 2014 8:58 am
by tirantious
got 5 minutes to waterblast the truck and even cleaned the engine up a bit. discovered some rust in the pillars and an oil leak where the dipstick meets the sump. i new i should have left it coated in mud :lol:
Posted: Sun Dec 28, 2014 9:20 am
by kbushnz
This fell out of santas sack... Going on my rear mount radiator... Feck they move some air.
Also scored some brownie points with the missus... And installed some new sounds in her little Rav.
The rest was eating and drinking with family...Now I need a week off to digest everything.
Posted: Sun Dec 28, 2014 9:35 am
by Mattman
I fitted a set of those to my Bighorn. They are awesome fans. I used three change over relays and a dual stage temp switch so that at mid temp they run in series so they go low speed and at high temp they run in parallel and go flat out.
Posted: Sun Dec 28, 2014 9:45 am
by kbushnz
Mattman wrote:I fitted a set of those to my Bighorn. They are awesome fans. I used three change over relays and a dual stage temp switch so that at mid temp they run in series so they go low speed and at high temp they run in parallel and go flat out.
Hey thats a sweet idea. Are you able to PM me more details on that setup please.
Posted: Sun Dec 28, 2014 9:50 am
by mudlva
can you post a wiring diagram on how this works
im running two craig davies 16" fans but at std closed circuit they are way noisy and also just about pull whats left of me hair off.
they work so well that the fans are cycling on and off. imho it would be better to just have them at half speed and run for longer but with a setting so they can also ran at full noise for harder work
Posted: Sun Dec 28, 2014 10:06 am
by Mattman
Here is a good link, about half way down the page is a wiring diagram.
http://www.aussiev8.com.au/holden-v8s/3 ... en-v8.html
I used that and also put in a SPDT switch so I can turn them off, have them on auto mode or run at at full speed. The switch has LED's in it so I can tell what mode it's on. Used diodes to prevent back feed to the relays from the switch.
I I used the tridon page to find a dual stage temp sensor that had the right temp range for my setup
http://www.tridon.com.au/Products/Produ ... 483&P=2012
Once I found the sensor I wanted I googled it and found that it was a BMW 5 series E39 sensor so went to pickapart and got the sensor and the wiring harness for $10.
Matt.
Posted: Sun Dec 28, 2014 10:27 am
by mudlva
Mattman wrote:Here is a good link, about half way down the page is a wiring diagram.
Matt.
cheers bud
Posted: Sun Dec 28, 2014 10:35 am
by imsohi
Awesome this is just the site i am looking for
Posted: Sun Dec 28, 2014 12:13 pm
by FORGE1
Fitted a 2inch lift to the old ladies 80 series.
Drowned Safari (Water over half of the roof) :( claim accepted and being taken away tomorrow. No pics as phones and camera went in the water and mates helping out get the kids out. Time to go shopping.
Huge thanks to Scruff123 for your help.
Posted: Sun Dec 28, 2014 3:14 pm
by coxsy
4 day weekend camping at Whirinaki, a bit of 4wd three trees removed of a short track that ended up taking all day ,the one near army camp for thoses in the know ,
visited on the last day by two trucks from Rotorua club, one people we saw since Xmas eve
we checked the hub temps when we got home with digital thermometer 42c. to 48c , and radiator was 70c :D
Posted: Sun Dec 28, 2014 7:17 pm
by KROOZA
Finally did hub seals and bearings on the 40 after watching it leak oil onto my floor for a few months :oops:
Then me and my boy went for a long overdue play down in the river 8)
Trail of oil down the tyre
New bearings and seals
All good, no oil leaks
:mrgreen:
Posted: Sun Dec 28, 2014 8:06 pm
by Crash bandicoot
Up'd the fuel, n boost on the mistral, now running 18 on the factory turbo and modded mechanical pump.
Tried to fit the fan under the cooler but ran outta room between the 3.2 and the bonnet, just got it fitting inside the bonnet intake ontop of the intercooler, so made up a water sprayer using the rear window washer and reservoir with a switch wired up to the throttle. will see how it goes next weekend,
Posted: Mon Dec 29, 2014 5:51 am
by BlakeNZ
Hey Crash, when did you sneak a QD32 into the Mistral???? Awesome!!!
Posted: Mon Dec 29, 2014 6:18 am
by Jay
FORGE1 wrote:Fitted a 2inch lift to the old ladies 80 series.
Bro.... you and water!?! haha - where'd that happen? I'll be up your way for a few days over new years if your gonna be around for a catch up.
Jay
Posted: Mon Dec 29, 2014 7:01 am
by Crash bandicoot
BlakeNZ wrote:Hey Crash, when did you sneak a QD32 into the Mistral???? Awesome!!!
after the 42nd trip. 2.7 was on it last legs turbo wise so got a whole QD32 for the same price as a new turbo. goes like a f'n stabbed rat now chirps tyres everywhere
Posted: Mon Dec 29, 2014 10:13 am
by coxsy
A after trip check, a real bugger moment the crank pulley has a little wobble,
in the throws of pulling the front off ,belts, radiator out to check ,bastard that nut is a tight sod, nut loose cone washer is the next problem
here the bastard thing
Posted: Tue Dec 30, 2014 10:55 pm
by NB42
Fitted a 2 inch body lift. Went to auckland yesterday and traded my 31s for some 33s.. Not as good condition but im still happy.. Also splashed out and got 4 new 15x10s
Posted: Mon Jan 05, 2015 1:32 pm
by Clint
coxsy wrote:4 day weekend camping at Whirinaki, a bit of 4wd three trees removed of a short track that ended up taking all day ,the one near army camp for thoses in the know ,
Good on ya's! Last time we poked our noses in there we came up against a tree that looked like a lot of work, was about to deploy the chainsawrosaurus on it but it started raining like buggery & was getting a bit late in the day so we wimped out.
Clint
