My front facing, front drive shaft transfer case seal has gone around Christmas time and is whizzing on my drive way
All the stores are shut, does anyone know the exact seal size/dimensions so that I can just grab one off the shelf ?, I do not want to pull my seal out yet.. and I suspect it's damaged from when the mechanic put the shaft back in after replacing my clutch (yes guys, I got lazy and got the mechanic to do it!).... bad idea... the problems that caused are ever lasting it seams
So if anyone knows the size, or even as a spare!!! That would be amazball's
Cheers in advance
Leyton Smith
