Prado solid axle dimensions?
Mattman
Post by Mattman »
Contemplating a SAS on my Pighorn with a Prado front end.
Anyone able to get a few measurements for me?
Need the width between the radius arm mounts on the chassis, same for coil buckets.
Also length of radius arms from diff so I can check where the mounts will sit.
Matt
kbushnz
Re: Prado solid axle dimensions?
Post by kbushnz »
Inside measurements as requested for a KZJ78 Playdoh
Need the width between the radius arm mounts on the chassis, 710 to 715mm
same for coil buckets. approx 840mm
Also length of radius arms from diff , this is from the center of the axle housing to chassis mount point is 830mm
Mattman
Post by Mattman »
Cheers mate!
Mattman
Post by Mattman »
Thanks Calvin - finally doing this.
The Isuzu chassis measures almost the same as those measurements so it looks doable.
