As most of you know I'm building my v30et Pathfinder... But im stuck as to what ECU to run.. I'm not 100% certain that the factory one will keep up.. And I'm unsure that i can run the vg30deTT one as it's dual cam rather than single cam? obviously the dual cam will have multiple cam sensors and various other differences. I'm not too sure what the differences are in the loom either so unsure weither it would work or not.. I did think about running a LINK ecu, but it's going to be a bit more work eliminating the distributor and will probably have to run a wasted spark setup of somesort as the link ecu reads the spark direct as far as im aware?
Any help would be really appreciated!
