If anyone can ID these, then I can get onto looking for brakes for him. Photos are of front and rear diffs, and he has cut mounts, etc off them and out others on there, but I'm sure someone here will still know!
ClassicCruiserSpares wrote:They are 80-84 FJ40 housings, fully floater in the rear use to have handbrake on the diff but has been removed. Front diff has been converted to disc brakes using early hilux gear. You can tell by the brake hose and backing plate setup. But the diff heads are out of a later model cruiser. The rear head looks like an 80 series one with the different shape pinion flange and and the stronger finned housing. The front head looks like a 70 series.
