does my saffy have a diagnostics port
For all Nissan related topics
Monty
Post by Monty »
hey guys a while ago i bought a diagnostics tool for nissans it plugs straight into the port and will give you real time /data logging or all sensors and what the comuter is doing i bought this since i own 3 other nissans so if the saffy has one it will be handy and ight be able to help you guys out if yours is running poorly
its a 1991
its just like a scan tool but you use a laptop not a scan tool cool ah
it also lets you change anything that the computer can change but it will loose all changes once you unplug it
thanks lee
I WISH I WAS A WINCH MASTER BUT I NEED A WINCH TO DO THAT
1991 safari with none of the boxes ticked im a fool!! SOLD
1996 nj paj 2.8td but with the diff lock box ticked :)
1978 DATSUN 180B sr20 POWERED
GQTROL
Post by GQTROL »
Your model of Safari doesn't have an ECU. The only computer in the GQ's is for the auto.
Monty
Post by Monty »
bugger thanks for the info tho
kiwipete
Post by kiwipete »
Will this unit work on Terrano's?
Id like to know more about it.
Ph 0212078472
DieselBoy
Post by DieselBoy »
The TD27 is the same as the TD42, no computers. I love that :D
Monty
Post by Monty »
i guess thats a good thing less things to go wrong, but also makes fault finding a little harder, i put it in my partners primera last night which went for a service about a month ago and found the o2 sensor is stuffed making the thing run too rich and lean
