08 ford ranger check light
Mat13
Post by Mat13 »
My speedo stopped working after driving it in the bush and on my home the check engine light came on. I got home and checked it over and found a branch wedged up underneath and had ripped my speedo wires out of plug. Got a new plug and got it sorted and speedo works now but check lights still on. I've tried disconnecting battery for awhile and didn't work. Is there any other way to reset it or do I have to take it to the shop. cheers
callum007
Re: 08 ford ranger check light
Post by callum007 »
Mine resets after a dozen starts or so. or I connect to the obd2 port and clear it with my phone.
Mat13
Post by Mat13 »
Ive ordered a Bluetooth adaptor for it, do you use that torque app.
Trundle
Post by Trundle »
Just disconnect the negative terminal on the battery for 5 mins and reconnect it should clear them ,
Mat13
Post by Mat13 »
na ive tried that
churchill
Post by churchill »
$18 for the adaptor http://www.trademe.co.nz/motors/car-parts-accessories/tools-repair-kits/meters-testers/auction-831897854.htm
Use "torque" on an android. Its really good, you get lots of information on how the engine is running e.g. boost pressure, fuel rail pressure, load etc and you can diagnose and clear faults.
Mat13
Post by Mat13 »
Just ordered one cheers for the help
churchill
Post by churchill »
no worries.
Return to “Tool Shed”
