Power steering boxes
Heath
Post by Heath »
Looking for options to add power steering to my HQ chassis based hot rod.
HQ boxes are getting hard to come by and usually flogged out (unless you get very lucky), they are also a little unpredictable at speed due to their design. Did I mention that a reconditioned one with swap of old one is up around $500.
I am looking at power steer boxes that will attach to the inside of the drivers side chassis (Right side) where the factory box goes. Maybe I'll have to get a US box to fit inside the rail (swap from outside left rail to inside right rail) if I cant find an NZ option that suits. Going to run the GM pump (may as well as I already have it) and will get hoses made to suit.
IFS box I guess would be suitable swinging the pitman arm in an arc behind the box.
Crash bandicoot
Re: Power steering boxes
Post by Crash bandicoot »
HQ did come with power steering try rare spares, but you will need the pitman aswell as the non p/s has smaller spline. alot of the race guys uses terrano boxes with spacers to bolt it inside the chassi rail
mudlva
Post by mudlva »
left hand drive bj73/74 box has pitman rear faceing and would be able to be fixed to the side of the r/h drive chassis. just a thought
Heath
Post by Heath »
Crash bandicoot wrote:HQ did come with power steering try rare spares, but you will need the pitman aswell as the non p/s has smaller spline. alot of the race guys uses terrano boxes with spacers to bolt it inside the chassi rail
Been to Rare spares - bit pricey and they dont have many (hit and miss if they have any on the shelf to be honest). When they do its luck of the draw (labels show internal condition after they are rebuilt - Green is good, Yellow is okay/marginal).
Might just keep the manual steering for a while longer and see how it goes. If its to heavy then I'll chase the power option.
tgaguy1
Post by tgaguy1 »
Why not think about powered rack and pinion from a jape car or a commy, falcon etc?
Crash bandicoot
company in aussie makes them specifically for the HQ but serious coin involved. $2850.00 AU.
to make another brand work chassi mods, with cert costs etc and get it set up so the geometry is correct , no bump steer, it would be easier to stay closer to box and draglink style.
but the blacks steering kits are certified, ADR approved and bolt in no modification required.
Heath
Post by Heath »
Crash bandicoot wrote:company in aussie makes them specifically for the HQ but serious coin involved. $2850.00 AU.
Seen those and they are on my lotto list, but unlikely otherwise. Cert costs arent a problem as this is a scratch build so everything is checked.
Heath
Post by Heath »
Missed out on a vitara power steering box on Trade me (thought about it too long and missed out - LOL).
I thought I might grab it and have a play around if I got it cheap enough. If I didnt use it I would just on sell it later. It did look promising though as they mount on the inside of the drivers chassis rail. Have a possiblity of a collapsable lower shaft that might do the job too
Such is life.
UBZ
Post by UBZ »
Early 80's Toyota Cresida /Crown
A Zuk power steering mod before Vitara boxes became common.
Mounts inside the chassis rail too
Mr Revhead
Post by Mr Revhead »
I reckon a trip to your friendly local wrecker or pick a part is what you need, spend some time on your knees having a look
zukmeista
Post by zukmeista »
Mr Revhead wrote: spend some time on your knees having a look
:shock:
:lol:
cornflake
Post by cornflake »
get one out of a rangi mitsi same saide ect pick a paert
Heath
Post by Heath »
Yep a bit of time on my knees might be in order - LOL - at picka part looking at car parts that is not .... parts. :mrgreen:
Return to “Tool Shed”
