My truck has been sitting unused and unloved in my garage for the last year... kids now rule my life. Use to be in to 4wd'ing and did most my driving in an old 80s Parjeo.. then kids came along the way.. sold the parjeo and then got a toyota ute to do it in... only thing is ive done stuff all 4wding since ive had the ln65.. so she now needs to go (so mrs can respend that money on house mods)
Bad parts..
- Has some rust that needs some attention, gave it a rust kill / filled in and then quick spray over to stop it spreading but still needs more love than im gonna give it. Just general surface rust on the edge of the bonnet and sills..
- Roof lining needs gluing back to roof
- has a slow front left tyre puncture (pretty sure the valve is to blame)
- was given a nasty respray before I purchased it with what im assuming is no prep, paint is flaking off in hunks..
- Rego has been onhold for 18 odd months
Has the following:
- Wellside ute deck has been chopped by around 45cm to make the entry / exit angles a little better.. was like this when i purchased 5 ish years ago
- removable tow bar
- Back ute tray is covered with a tredplate shooting deck
- has a detachable electric 9500lb winch on it with front and rear mount points.. done at an engineering shop
- dual battery (but still 12v) setup.. roses electrical fitted
- 32 inch but worn (would still get wof) maxxis mudder..
- 2x lock right lockers with a larger v6 9" hilux rear diff - this was put in less than 1000kms ago by 4WD Upgrades (although rear diff now seems to be clicking, would suspect the shims need resetting or the likes as it has hardly travelled since being put in).
- Old school barry crump bull bars.. wrap around the front sides
- Radiator reconditioned.
- Front pully / key re done (was wobbly as hell previously) – done at Roses
- oil changed fair regularly when in use (has been parked up for around 1.5 years but turned over every now & then)
- 3L was swapped in by previous owner (2.8L non turbo) – was out of HiAce. Not certed but was never pulled up on it at WOF time.. came with 2L orginially I think?
If your looking for something like this msg to sort out a viewing.. else will be going on TM.. but if I can sell it before hand I will
older pic of me taking some green waste to the dump - http://postimg.org/image/d6rm84zmj/
FS: Toyota LN65 with 3L
Re: FS: Toyota LN65 with 3L
hello
how much for the ute ???
thanks
thanks
