strop and winch rope mounts
Mattman
Post by Mattman »
Anyone have suggestions for good mounts to hold strops and excess winch rope?
Had an incident with a loose strop a week or so ago that caused some damage.
Have a tube front bar with winch and hooks. Considering some sort of tubes or something I can loop the strops around but worried about WOF time etc.
Any pics or suggestions appreciated.
Matt
Smurf
Re: strop and winch rope mounts
Post by Smurf »
Drill two holes in the top of your bar and weld a nut into each one, bolt in a couple of 150-200mm long bolts to hold your cable etc.
When not needed unscrew them and wind in two 20mm bolts to fill the holes.
Mattman
Post by Mattman »
Cool. Thanks.
Crash bandicoot
Post by Crash bandicoot »
This is the road legal option two holes either side with some 10mm ali tube bent into a U shape and slid in each side. Holes are drilled at 10mm aswell to make tight fit.
Return to “Tool Shed”
