I filled up monday and was reminded by the noisy injector that more 2T was needed,I've been adding air cooled 2stroke oil to the fuel for about 8 months after reading various
pros and cons.This was prompted by a discussion on the effects of low sulphur fuel having low lubricating properties most affecting older diesels,and two stroke oil as an
additive to offset it.I use .5%,or 1/2 a litre in 100lt of fuel,definately quiets the injectors and pump and seems to reduce exhaust smoke.[ the following cars are closer now
when I'm climbing hills] Hope this info is helpful,
Cheers,ONC
2T in your diesel fuel
Re: 2T in your diesel fuel
Few people on here have been doing it for a while now. Works quite well in my patrol. Few threads about it on the aussie forums too.
http://www.offroadexpress.kiwi/Forums/viewtopic.php?f=46&t=17960&hilit=2+stroke
