2009 Holden Colorado won't start?
Moderators: Steve_t647, Tech Authors
Just went to start a 2009 Holden Colorado in reverse by accident. Chucked it in nuetral to start it and now it won't even let me put the lights on? When I turn the key nothing happens. A few lights on the dash and that's it. Anyone have a clue? Rather not have to tow anywhere. Thanks.
Re: 2009 Holden Colorado won't start?
its an aussie and its a public holiday maybe????
start checking fuses and relays auto or manual?
Haha possibly... I'll have a look at that tomorrow. Roughly had a look at the fuses. It's manual.
pull off battery terminals an leave for a few hours to reset the ecu
It's acting like the battery is flat now... It was sweet as before. Won't jump start though. I'll try leaving the terminals off over night. Thanks for the help.
check all your battery terminals are tight and your earth straps are all good clean connections
Check the master fuse under bonnet. Maybe the excess load from trying to start in gear overloaded the "fusible link or fuse".
Just guessing though.
