Hello,
Nearing the end of retrofitting power steering into my 1988 110 and was wondering where I can get some hydraulic hoses made up that don't cost the earth. Preferably out West Auckland somewhere.
I have the fittings for the box but not the pump, although I'm pretty sure its a standard fitting on the pump. I even have the discovery 1 steel hoses it came with.
Any suggestions?
BadCo.
Power Steering Hoses
- jonossiksilvia
Re: Power Steering Hoses
first time round i got hydalink out to my house to do it $150 cash all up.
second time round when i changed a few things i used braided hose with nylon inner made for high pressure and an fittings and made myself in 30mins and $40 bucks of parts.
you only need to get the high pressure side made up the return is low pressure so you only need a bit of hose and a few hose clips and a cooler if you want to get fancy
, if you measure up the length for your high pressure line you can go into hydralink or enzed or whatever hose place you've got nearby and they should be able to crimp up a hose with the right ends while you wait
... the high pressure hose never comes $cheep$ though
jonossiksilvia wrote:first time round i got hydalink out to my house to do it $150 cash all up.
That's a lot less then I thought it would be.
derk wrote:you only need to get the high pressure side made up the return is low pressure so you only need a bit of hose and a few hose clips and a cooler if you want to get fancy, if you measure up the length for your high pressure line you can go into hydralink or enzed or whatever hose place you've got nearby and they should be able to crimp up a hose with the right ends while you wait
This I did not realise, makes sense though!
Cheers for the info guys.
