80 series gearbox oil change
Hi I am going to change the oil in my gearbox and was wondering what you think the best oil is to use and generally how much oil goes in there. Shifts fine at the moment but not sure if it would need replacing yet?
How often should this fluid be changed?
Tom.
Tom.
hachi_roku
Re: 80 series gearbox oil change
Dont use a GL5 rated fluid, the 80 series syncros are quite soft... i found the later model fluids it just didnt like it.
I used a GL4 rated fluid from aussie ( penrite oil ) i cant remember will try and see if i still have floating around so i can give you the spec.
Give Elf (Lubricants NZ ) a call in chch 0800 353 645 and they will freight anyway and about 45 buck for GL4.. It was the only place I could get gl4..
Supercheap sells Nulon GL-4 off the shelf but im sure most places could order some in other brands. This is presuming its manual?
johnny262 wrote:Supercheap sells Nulon GL-4 off the shelf but im sure most places could order some in other brands. This is presuming its manual?
Yup manual. Is Nulon or Penrite the way to go (GL4) and what amount of fluid do they take?
hachi_roku wrote:Dont use a GL5 rated fluid, the 80 series syncros are quite soft... i found the later model fluids it just didnt like it.
Okay thanks dude.
Big wrote:Give Elf (Lubricants NZ ) a call in chch 0800 353 645 and they will freight anyway and about 45 buck for GL4.. It was the only place I could get gl4..
Thanks Big, what size containers are they?
The 2 bottles I got are 5ltr containers each.. was real good as it came to me instead of having to go and get it..
Did you manage to find the spec? Ive read 75/85 or 75/90?
hachi_roku
Sorry dude, I'm in the Cook Islands.. But will have a look when I get home.. Probably took late anyway
Bump what does everyone else use?
GL4 from Elf.. I wouldn't use a gl 4 / 5 mix.. with softer cyros gl5 will eat them.. its what I have found in my 70 series xfer .. think what to use when date of manufacturer as newer oils these days are way more sophisticated than the older oils.. K.I.S.S is the rule I would use
Big wrote:GL4 from Elf.. I wouldn't use a gl 4 / 5 mix.. with softer cyros gl5 will eat them.. its what I have found in my 70 series xfer .. think what to use when date of manufacturer as newer oils these days are way more sophisticated than the older oils.. K.I.S.S is the rule I would use
Cheers. I am also needing to know what weight of oil to use?
75-90 weight would be fine GL4 is what is recommended in the fsm but it also states GL5 but I would NOT use GL5
