Safari hard to shift out of 4 wheel drive
- waterboy123
- Driver/Navigator
Was mucking around with putting my safari (95 SWB 4.2 turbo auto) into 4wd tonight and it would go in sweet as, but took me a good five mintues to get it back into two wheel drive tried everything ended up driving around the block and stop and slammed it back into 2WD, it's been abit stiff sometime's before but this time was a right pain in the ass, any suggestions??
I take it that when you drove it round the block it was on a sealed road??
If you drove it home to your place in 4wd on the road, and than round the block, then yes, its gona be hard to put back in 2wd. The transmission would have wound up
I could be way off the mark with that comment though
Did you make sure you were stationary and had the auto trans in neutral???
- waterboy123
- Driver/Navigator
hmmmmmmm
Ifn its anything like my mistral to get it outta 4 wheel drive u gotta back it up at least 10 meters to disengage 4 wheel drive give it a try
Terrano TD 2.7 and a ssangyong Rexton
