The parts truck that I've got is a 1994 Nissan Terrano, V6 manual. It's nothing special at all.. Although, I have noticed that the rear axle is disk brake...
So, would it be worth running the rear axle out of that truck instead of my drum brake setup? My current diff is LSD & is tight as ####! Almost to the point where you would think it is running a locked diff. The other diff is also LSD, but appears to be larger than mine? I haven't actually done any measurements or anything but visually it looks different...
What's everyones thoughts?
Any help appreciated!
