SWB GQ overhaul
Posted: Wed Mar 11, 2015 7:08 pm
Guys I'm back on this forum after being away for a few years. A lot changed so stopped 4wding but kept my trusty GQ (Rosie). Anyway so Rosie went from bouncing off trees to off curbs in the last 3 - 4 years. The TD42 has always had a fair bit of blowby and adding the turbo has not improved that situation. Shes now seriously chuffing, and in itself I'm not too concerned except get into a tough wellington head wind and I'm nearly changing down gears. Add a trailer and I'm in the slow lane. I suspect that points to lots of compression disappearing somewhere other than the exhaust. Anyway, just finishing off sorting a 460 Bronco and now money is coming right am seriously thinking about getting Rosie back to a solid dedicated 4wd truck and getting back into 4wding. Have always missed it so keen to give Rosie a makeover and start all over again. What I'm starting with:
Running gear
TD42, 310,000ks and chuffing bad plus down on power, aftermarket turbo at 15psi max via an A2A intercooler and full 3 inch exhaust. Std pump etc with a turn of fuel until my EGT's were topping about 550. 5 speed manual where thirds not too happy changing down. Was told a 4 inch suspension lift when I got it but its gotta be way sagged as have seen 2 inch lifts with more spring in their step. Recently recond LSD rear diff. Body etc has rust round the windows, dents everywhere (don't care), 2 inch body lift, shortened rear quarters, good front bars, rock sliders and rear wrap arounds, onboard compressor, and VERY slow electric winch due for a rebuild. Legacy seats and crook speedo and rev counter (they have the "AHH I'm doing 180k" thing goin on).
So heres what i'm thinking. I love the truck and now have some money to spend on her and want to start forming a plan of attack. Very interested in experienced and educated opinions as i know there are a bunch of you that have done this stuff. So, what do I want? More power (go figure). Probably not as far as to need major internal engine modifications but probably as much as you can bolt on to a recond engine. Maintain great torque but pull to say 4000. Don't think my current engine has ever quite got to 4k. Sounds like its gonna dump its lunch past about 3500!! Basically a very capable club truck thats reliable and pretty much dedicated to 4wding with the torque/HP to hold its own on the highway.
So heres what I'm thinking:
Engine - love a V8 but reality tells me recon the TD42. Then thinknig new pump, 12mm plunger, boost compensator and existing turbo/intercooler running 15 PSI. Can change turbo later if its not enough (like the compound idea but maybe too far/complex?). Thoughts? Also what about headwork, balancing, inlet manifold etc or should I just go with a stock recon?
Gearbox - probably keen to stay 5 speed. May be old school but like gears and not use to autos. Could be swayed? Maybe a Lokkar in the front diff and probably leave the rear LSD??
Suspension - needs a make over. not too fussed on huge lift as I've never had a time where current set up was not high enough (except diffs??) and also concerned with center of gravity shifts but keeping wheels in touch with the ground I'd like i.e. better articulation, was thinking 3 inch with extended radius arms but what else would you recommend?
Body - probably a black mark but planning on trimming to a ute. Only cos i like that look. I'd love to have a better reason like "oh what about the weight saving or rust etc" but in reality I just like the look of these trucks as utes. Also thinking about shifting some weight rearward e.g. mid mount batteries and maybe look at fiberglass front guards/bonnet etc, plus likely 6 point roll cage, just cos I'd feel safer if i ever did something stupid.
Trucks I have saved as ideas - Recall Taz did a nice conversion as did Pigfarmer. Still have the pics. Muddyaz Truck I'm big into but more because of the power and the fact it was still a TD42. would like that power but maybe toned down a smidge for reliability. Be great to get a ride in a well tuned TD42 alogn the lines I'm thinking just to see what good power in these things feels like. Mines always felt sluggish. The turbo I think just delayed the inevitable.
Anyway be interested in your views. Budget...Hmm...I dunno, could maybe go out to 10 - 15k. Sons a welder/engineer so bodywork and basic mechanics we'll do but the recon and parts I'll be paying for. Look forward to your comments and experience.
Running gear
.jpg)
.jpg)
.jpg)
