When your electric windows are becoming slow / sluggish to open and close, you will find that the loom to window motor plug starts to blacken inside.
the window motor starts to struggle as it's not getting enough power to drive it.
Solution: Chop the plug off and hard solder the motor to the loom. Worked wonders for mine.
Also don't forget to clean and lube the window track and rubber guides.
80 Series Electric Window issues
- Shuttle Queen
- mudlva
Re: 80 Series Electric Window issues
What product did you use to lube the rubber?
Who knew Prados could fly?
- Shuttle Queen
I just give mine a good dose of silicon spray from time to time.
