Indicator Issue
Indicator Issue
Ok so I have had LED tail lights on my '88 Rugger for ages and they worked fine. Recently changed front indicators/park lights to LED also and now indicators don't work? Hazards still work fine, fuse is intact. Have non load sensing flasher unit installed. Used to have same parts on my Suzuki with no problems so not sure why it's not working on this truck. Any suggestions please?
Re: Indicator Issue
Do the front LED's light up when hazards are on, and normal indicators work when swapped for the lEDs?
Maybe it is looking for more resistance?
Re: Indicator Issue
Yep all lights flash with hazards on.
Re: Indicator Issue
I have some inline resistors, used them when I put LED's on my motorbike to slow the flash rate before I changed the flasher unit.
Can drop them off in town, Whangarei tomorrow, if you want to try them in the circuit to see if they work
Re: Indicator Issue
Sorry maybe didn't make it very obvious in post, I have a non load sensing flasher unit fitted so resistance shouldn't matter. Thanks for the offer though.
Re: Indicator Issue
Do the indicators work if you put the bulbs back in?
Re: Indicator Issue
Not sure as I don't have them any more.
Re: Indicator Issue
Even with a non load sensing flasher you need some load to turn it on. Try a resistor on one indicator and see what happens, even a bulb test lamp may be enough for testing.
Re: Indicator Issue
Ok thanks I will try that tomorrow and see if it works.
- mudlva
Re: Indicator Issue
yep you will need a resister, been there and done that
and i think you need to ground the resister as well as i had it in series and it didnt work,
auto sparks just gave me that stupid face after i described what i did, and then set me straight
