I have a 1995 4x4 hilux, the indicated in the bulbar wasn't working when I bought the truck so I jumped under a couple days ago and tried to wire it up as had no connections on it. Anyway it didn't work and now when I wqas playing the same side indicated in the guard has stopped working and the side light.
All the others are fine.
The indicated fuse is fine and the bulbs are sweet as I have swapped the indicters around.
I am stuck........ The wiring looks factory and doesn't look to be tampered with in the past. Any help would be muchly appreciated as I have just taken to a sparky and they want a minimum of $80 to even look at it.
Cheers Chris
