wheel fitment on GQ safari
For all Nissan related topics
RedPower
Newbie
Newbie
Post by RedPower »
Hey Guys/Gals?
New member to the Nissan forum from just selling my SWB bighorn :( and replacing it with a SWB Safari. :D
The truck has a 2 inch lift with both sway bars removed my tyres are 33"x12.5 R15s which are rubbing on my guards (while flexing) due to the offset of the rims.
The Rims are 15x10 with a -44 offset i'm happy to go to 15x8 but not sure which offset would suit best?
I don't want to raise it as i like to keep my 4x4's as low as possible,
and can't massage the guard lips due to the rubber flares that are fitted.
cheers.
Crash bandicoot
Re: wheel fitment on GQ safari
Post by Crash bandicoot »
Depends on where they are rubbing, is it the outside edge of the tyre coming into contact? if so you may just have to reduce the offset but still keep a ten inch wide rim. or reduce the full lock stoppers but sacrifice turning circle.
datsunsafari
Post by datsunsafari »
15x8 -22
kiwibronco
Post by kiwibronco »
Yep I've got 33's pretty sagged lift and think offset is -24 and no rubbing issues on 15x8's.
charo249
Post by charo249 »
Unscrew flares bend guards up then re attach flares
As mentioned above.
Go to 15x8" rims . They are available, suitable for safari fitment from -19 thru to -28 in some cases (I think)
It will pull the outside edge of the rim in roughly 2" and also keep your beads better seated on the rim for offroad use :-)
My thoughts ;-)
RedPower
Newbie
Newbie
Post by RedPower »
Hey thanks for all the reply's went for 15x8 -20 offset and flexed up the truck and all good no more rubbing also drives alot better on the road.
